Won’t crank - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 8 (permalink) Old 05-07-2019, 02:55 AM Thread Starter
On Easter, my wife took the 2002 Malibu to church. When she went to leave, the car would not start. Would not even try to start when she turned the key. Lights came on but wouldn’t even crank. She says she kept turning the key on and off and after a few minutes it started.
It’s been fine since then, until last night. I got off the train to come home and it did the same thing to me. No cranking, lights came on, everything normallly the same but won’t even try to start. Theft light is NOT on. Fuel pump primes (it was replaced last year) My Bluetooth adapter when plugged in shows the battery voltage at 12.2
What can it be?
Please help!!
Jfinesse2000 is offline
post #2 of 8 (permalink) Old 05-07-2019, 03:37 AM
Re: Won’t crank
Very possible that the key tumbler and ignition switch (2 separate parts) have worn enough and need attention, aka replaced.
post #3 of 8 (permalink) Old 05-07-2019, 04:37 AM Thread Starter
Thank you. Just from reading around the internet for similar issues, that is one that I see often. Is it also possible it could be the starter? Where is the starter on an 02 Malibu?
post #4 of 8 (permalink) Old 05-08-2019, 02:27 AM Thread Starter
It’s definitely the starter. Tapped on it and it started right up. Watched a couple of videos on YouTube and it seems like a pretty easy job. Will attempt to do it myself.
post #5 of 8 (permalink) Old 05-08-2019, 05:42 AM
Darthz's Avatar
Re: Won’t crank
Ya brushes are shot in the starter.... they are really easy to rebuild yourself if you felt like it
Darthz is online now
post #6 of 8 (permalink) Old 05-09-2019, 05:48 PM
Certified Technician
JLDickmon's Avatar
Re: Won’t crank
it's not the brushes.. it's the bushings on the end of the armature in the case..
Back in the day (when I got into this business, 40 years ago), we rebuilt our own starters as a normal course of business.
I used to be able to replace bushings, re-wind armatures and stator magnets, replace the brushes.. then the "discount auto parts places" came along.. you could buy the parts to rebuild your own unit for $19, you could buy a fully "rebuilt" starter for $24.. now these permanent magnet starters (smaller, lighter, higher torque) have taken over the market, are crimped together, and as such aren't really designed for "user serviceability."
2011 LS, 2.4L, six-speed ATX
JLDickmon is offline
post #7 of 8 (permalink) Old 05-11-2019, 11:38 AM
Darthz's Avatar
Re: Won’t crank
Ya.... our kits up here were around 40 bucks.... buts that like 30 years ago
post #8 of 8 (permalink) Old 05-15-2019, 03:09 AM Thread Starter
I replaced the starter yesterday. All is well now. Thanks.
2007 no crank, no link to ECM Patsmark Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 02-15-2018 01:28 AM
No crank no start when hot Rg8665 Problems/Service Issues/Troubleshooting (Generation 7) 0 05-06-2016 04:16 PM
No crank problem jhoop Problems/Service Issues/Troubleshooting (Generation 7) 4 01-11-2016 06:54 PM
Weak first crank, then stronger second crank gets ignition ChPat Problems/Service Issues/Troubleshooting (Generations 5 & 6) 1 07-01-2013 07:13 PM
Crank Sensor Question dalejamin Do It Yourself Maintenance (Generation 7) 0 08-07-2009 10:32 AM
