A/C blows fuse #37 every time - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 8 (permalink) Old 05-15-2019, 03:15 AM Thread Starter
My ‘02 Malibu has an issue where it blows the #37 fuse when the A/C is turned on, which also kills the gas gauge and temp gauge. The compressor engages for about 5 seconds and then the fuse blows. Can anyone help me with where to start with figuring out what is wrong?
Thanks
Jfinesse2000 is offline
post #2 of 8 (permalink) Old 05-15-2019, 03:47 AM
Re: A/C blows fuse #37 every time
Unplug the AC compressor and then turn the AC on. If it still blows the fuse then the wiring is the issue. If not, then the compressor has an issue, so maybe the clutch itself is failing.
post #3 of 8 (permalink) Old 05-15-2019, 04:14 AM Thread Starter
I did pull the relay, and the fuse did not blow when the ac was turned on. Is that the same as unplugging the compressor?
Thanks
post #4 of 8 (permalink) Old 05-15-2019, 04:25 AM
Partially, but not completely.
Pulling the relay tests only the control circuit, the part that tells the relay to turn on. It doesn't apply 12V to the wiring between the relay and compressor. By unplugging the compressor, the relay will engage and any wiring between the relay and AC will be powered up. If it draws too much current then the fuse will blow. If not, then the issue is at the compressor.
post #5 of 8 (permalink) Old 05-15-2019, 04:54 AM Thread Starter
Great, thanks for clarifying. I will try that when I get home tonight.
post #6 of 8 (permalink) Old 05-15-2019, 05:16 PM Thread Starter
Jeez I am having a hard time unplugging the little harness from the compressor. There doesn’t seem to be a tab on it.
post #7 of 8 (permalink) Old 05-15-2019, 08:29 PM
I'm not sure if it unplugs directly at the clutch or if it goes a little ways away before there's a plug.
post #8 of 8 (permalink) Old 05-16-2019, 03:46 PM
DaveNDawn's Avatar
Our 2000 has been having the same issue. When you solve the problem, could you please let us know what it was and how difficult it was to fix?
DaveNDawn is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Darthz
Second time dash light fuse has blown in a week Arie Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 06-18-2015 05:34 AM
First time audio install. No ACC voltage, and I need some advice. OH!3 Modifications (Generations 5 & 6) 4 05-09-2015 12:09 AM
My 2000 malibu LS A/C blows hot air for about 10 minutes after parked under the sun. yvm_22 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 37 06-19-2012 05:12 AM
how to change the accessory fuse on a 2008 malibu jadera Do It Yourself Maintenance (Generation 7) 3 07-10-2011 06:43 AM
After market stereo just died, no power? Fuse? bttang83 Problems/Service Issues/Troubleshooting (Generation 7) 5 04-18-2011 05:33 AM
