2013 malibu turbo fuel psi - Chevy Malibu Forum: Chevrolet Malibu Forums
 1Likes
  • 1 Post By Plague
post #1 of 6 (permalink) Old 03-27-2019, 10:32 AM Thread Starter
I was wondering what the 2.0 turbo fuel rail psi is, I'm having some issues with the car jerking under load it's showing 3100 kpa at idle. Thanks
Jimlogger is offline
post #2 of 6 (permalink) Old 03-27-2019, 12:06 PM
cp-the-nerd's Avatar
Re: 2013 malibu turbo fuel psi
I don't have the answer for your question, but is it throwing any codes and have you addressed the possibility of bad carbon build up from the direct injection?
2017 Chevy SS Sedan
6.2L LS3 V8/6-Speed Manual
cp-the-nerd is offline
post #3 of 6 (permalink) Old 03-27-2019, 03:17 PM
Also, others can probably help you a bit better if you'll also include the number of miles on the odo, the kind of gas you use (octane, whether it's Top Tier, how low you go before filling up, etc), and any other stuff that could make a difference for members offering to help.
post #4 of 6 (permalink) Old 03-27-2019, 07:06 PM Thread Starter
It has only has 70000 miles i run 89 octane fill up when it gets around 1/4, the car started out with a small sudder around 42mph I replaced the plugs and coils but still no chance the rpms will fluctuate up and down just avarge driving with no incline but more noticeable uphill, the other day I was driving and it seem like It had no boost It gave a code p0014 and p0171 i replaced the vvt solenoid on the ex side and it fixed the boost problem but it still doing the same thing as before rpms still fluctuate thought it could be the torque converter but it does it when cold. When you first start the car it will black smoke for just a second the tail pipe tips are black like it running rich.It dont use any oil and is powerful like it should be, would a boost leak make it do this?
post #5 of 6 (permalink) Old 04-06-2019, 02:16 AM
Plague's Avatar
I am in no way an actual technician and you're better off getting a professional opinion over what I say.
That said 3,100kpa seems like it's right around the normal operating range of a direct injection idle pressure. 3,100kpa is about 450psi. Of course this isn't GM specific but a direct injection engine can run from about 300psi(2,000kpa) to around 2,500psi(17,000kpa) all depending on engine type, load, air induction, ect.
At idle your engine isn't under a load and there's no boost being produced from the turbo so your fuel demand will be low. For now i'd say your 3,100kpa is about normal....... Unless you can find someone with more knowledge that can say for certain if it's low or not.
DrivenDaily likes this.
2010 Chevy Malibu LTZ 2.4 Ecotec
Fully debadged, 25% tint on front doors & 15% on back doors and rear window, crappy Hypertech tuner, and HHR SS wheels with 245/45/18 tires
2002 Ford SVT Lightning supercharged 5.4
MP Blower @ 15psi, SCT Xcal2 tuner, catless Magnaflow exhaust, lots of suspension, lots of interior, and lots of other stuff.
Plague is offline
post #6 of 6 (permalink) Old 04-07-2019, 05:26 AM
repairman54's Avatar
Cold start up normal to puff black as rich fuel is needed for cold starts.
P0171 code
Possible causes
•Intake air leaks
•Faulty front heated oxygen sensor
•Ignition misfiring
•Faulty fuel injectors
•Exhaust gas leaks
•Incorrect fuel pressure
•Lack of fuel
•Faulty Mass Air Flow (MAF) sensor
•Incorrect Positive Crankcase Ventilation (PCV) hose connection
John
09 Malibu LS
11 Tahoe LTZ
16 Equinox LTZ 3.6
01 FLHR
Ski Doo's & Sea Doo
02 Malibu traded
67 Malibu sold
64 Malibu sold
07 Mustang GT 3 pedals sold
repairman54 is offline
Separate Fuel Pump (not assembly) for 2004 Malibu LT 3.5L SBLfromNS Problems/Service Issues/Troubleshooting (Generations 5 & 6) 0 07-17-2017 02:54 PM
2013 Malibu LTZ Turbo-Second Thoughts? vpm47 General Discussion (Generation 8) 28 05-17-2013 05:24 PM
Observations on 2013 Malibu dcsforum General Discussion (Generation 8) 27 10-28-2012 04:34 PM
2005 malibu no fuel pressure cnew0181 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 12 07-24-2012 06:59 AM
2013 Chevy Malibu to Get 2.0L Turbo AutoGuide.com General Discussion (Generation 8) 22 12-17-2011 05:56 AM
