Brake pad and rotor question - Chevy Malibu Forum: Chevrolet Malibu Forums
 7Likes
post #1 of 31 (permalink) Old 04-12-2019, 02:04 PM Thread Starter
Hello everybody,
I currently have 35,550 miles on my Malibu. I took it in to the dealer today for a coolant flush service as the DexCool is at the 5 year mark. I have been noticing a metallic grinding noise when turning right, all the time and mentioned to my service advisor that I thought it may be a brake issue, long story short, my advisor came back and said the "front brake backing plate is hitting rotor due to rust build up" but also mentioned it was rusted through (which one is it? lol) he said I would need to replace front pads and rotors. Stupid me didn't look and just took their word on it. My question is, does this sound legitimate? I will definitely be getting a second and third opinion but wanted to consult with you all first.
2014 Malibu Turbo
Malibu2LZ is offline
post #2 of 31 (permalink) Old 04-12-2019, 02:36 PM
Re: Brake pad and rotor question
Hard to say from my knowledge but seems possible. Have you ever had your brakes serviced in the 5 years and do you live in a rust belt?
Sent from my LG-H873 using Tapatalk
Pascal
pascal_poirier is offline
post #3 of 31 (permalink) Old 04-12-2019, 03:26 PM
cp-the-nerd's Avatar
Get a picture of the affected rotor if you can. The factory rotors get pretty rusty, but I'm surprised it got that bad in 5 years. Usually you can just turn a rotor after the first brake pad change and it's still good till the next replacement.
2017 Chevy SS Sedan
6.2L LS3 V8/6-Speed Manual
cp-the-nerd is offline
post #4 of 31 (permalink) Old 04-12-2019, 03:30 PM
"Backing plate" is the splash shield. If it's rusted then that's not a brake issue.
Have them walk you back and show you what's going on, then make a choice.
cp-the-nerd and SilverSport like this.
post #5 of 31 (permalink) Old 04-12-2019, 09:18 PM Thread Starter
Thanks all for the replies. Never had the brakes serviced or had pads replaced as I still have an adequate amount of life left in them.
I’ll try to get a pic of affected wheel/brake and post it.
Definitely will get more opinions on it and have them show me in person as this isn’t a dealer I typically use and pretty skeptical of them.
Thanks again y’all!
2014 Malibu Turbo
post #6 of 31 (permalink) Old 04-12-2019, 11:09 PM
Being a mechanic I would look at those brake rotors over good. Light rust is normal if it's been sitting. Putting Akebono's on the Malibu: https://akebonobrakes.com/performance. next week.
Chevyman4life is offline
post #7 of 31 (permalink) Old 04-13-2019, 03:58 AM
Cool Re: Brake pad and rotor question
When replacing the pads and doing the whole job, will you be replacing the rotors as well?
If so, do you have a preference on brand or type?
post #8 of 31 (permalink) Old 04-13-2019, 07:01 AM
Last year I head very similar noise coming when turning at slow speed in sharp turns in parking lot. Had about 49K miles back then. I took all rotors and grind off the rust around outside diameter of each rotor. Noise went away till now as it is slowlly coming back at now 59K . Now I think of getting coated rotors as I don't want to do it every 10K miles.
chris6101 is offline
post #9 of 31 (permalink) Old 04-13-2019, 07:21 AM
Didnt yours come coated? The spec for my car was for premium coated rotors only as that was factory install when I had to replace them due to warping.
SilverSport likes this.
Pascal
post #10 of 31 (permalink) Old 04-13-2019, 10:05 AM
I can only assume that my rotors are factory non-coated. That is why there is big rust ring above where pads
are tuching rotor. this is not my rotor but looks similar.
