I recently bought this car with 39,000+ miles.
Because it apparently sat unused for a couple of years I had to replace all four tires. Also had to replace the fuel pump due to a cracked plastic connector at the entry point to the fuel tank.
Now I've found the cruise control, door lock, pedal adjust, and mirror buttons do not work. One person suggested the Body Control Module.
Could the issue(s) be somewhere else?
Take a look at this fretting corrosion thread. When a number of different sub-systems are affected like this, the issue could be connected right there at the BCM.
