1 - 19 of 19 Posts
car starts and runs but warms up a little sputters and dies. No clear codes that we can see. Camshaft position sensor maybe? Car dies and will restart but dies again. Also running rich
Ok not sure what else i can say to describe the problem. Weve tested fuel pressure, replaced fuel pump a while ago, does have oil leak which ive read can interfere with sensor function
Take out the air filter and see if it runs, it could be caused by a clogged air filter
Thank you i did try that and problem persists
Hmm, that was my issue several years back, I will try and find out more soon. I have a 2004 Malibu lt with 210,000 with a 3.5 so it's a different engine than yours and I've had it for over 10 yrs
Basically you need to help us help you.
New spark plugs?
Plug wires?
Oil filter and condition
Air filter and condition.
Fuel pressure?
Known issue or just suddenly appeared?
You basically said... my car starts and then dies. Whats the problem.
Provide as much info as possible and we can help you as much as possible
Sent from my SM-G975U using Tapatalk
Check your alternator wire see if the red wire from the battery. Make sure the nut on the alternator us thight also Make sure you have a good ground (Black wire) from battery to the body and that the positve and negative battery screw are tight (gm side post) to me your issue seems to be a loose wire cause it starts so something seems loose 🤔
Does the fuel pump sound like it’s running. Also check the fuel pump relay to see its is any good or going bad it may have black burn on it.
If it is running to rich then you don’t have enough air in the mix of fuel. Air filter check back to the engine one of the air sensors oR filters needs your help!
At 185'000 km i just changed the plugs for the first time( well....98'000 km . Since i have driven it ).... i doubt its a plug and wire issue. ... totally amazed at how the heck they last so long
Need the actual fuel preasure number....what psi? The fact you have no codess... if it cant run enough to go into closed loop...gona be more of a chase and check items out..... i have seen a clogged cat stall an engine....but wouldnt restart. ... stuck IAC , spark module ( forget if these cars have an EST module) . Then weird stuff like wireing coming loose when it fires up..... just guesses though
Whats the actual fuel preasure
Discussion Starter · #12 ·
it does go into closed loop thats when it seems to have the issue the long term fuel trims go off. sensors plugs and commands all seem intact cleaned the MAF and replaced filter no improvement we knowits running rich just csnt tell why and still no codes
Tossing some more info out there. Wiggle tested battery cables, and alternator output wire. Tight.
Watching live data: Car starts and runs in open loop.
Shortly after going to closed loop, it begins loading up, running rich, and then dies. It will generally restart, with some foot opening the throttle.
Long term fuel trims go way negative right as it dies, so the pcm is seeing it running rich. I can command it to stay in open loop and it will idle longer.
Air filter is new.We cleaned the MAF and throttle body. Accelerator pedal sensor and throttle body stay in sync for commanded positions.
Will run a fuel pressure test, and I think we can dump pressure as it starts loading up.
we did replace the fuel pump March of 2019.
I would suspect the MAF or O2 #1 as when on open loop it runs on preset fuel maps in the PCM. Once O2 heats up to operating temp then it goes to closed loop fuel maps. Check MAF inlet air temps also.
Also check engine temp. sensor as if it reports engine colder than what it is PCM will use a richer fuel map to prevent cold stalling.
Just a few ideas to solve the mystery.
A Car Usually needs Fuel, air, Spark, and timing. To run But it also needs a good Ground. You may have the greeny meanys. Playing with you. Check them for what you need for the Vehicle to to run. To see they are tight, and little pull on them, to see if the greeny meany’s are at work. Don’t pull like a hero. As you look for them.
Temperature sensor affects fuel trims alot. In obd1 it was the collant sensor that told the car to go i to closed loop .....not sure what does it now with bd2. Sometimes due to electrolysis. ..the sensor bungs up a bit..... i would put in a new one instead of cleaning tue old one. They used to be a cheap item.
It used to be a sensor that gets bunged up and not throw a code. You may see issues in the data from this sensor..... somthing is obviously affecting fuel trim. ... check collant sensor data..... i.e temp.... maybe voltage.
Evap system was dumping raw fuel into the intake manifold, due to a vent solenoid that was sticking shut, as well as rounding up to the next dollar at the pump. It was coincidental that the evap system leak test would complete at about the same time it went into closed loop. I’d like to install a jet in the evap purge solenoid, so if it happens again, it will meter the fuel better.
Fuel coming through the purge valve means your charcoal canister is loaded up with fuel and defective.
Zero liquid fuel should be coming up to the purge valve.
Reactions: Darthz
Nevvvvvvvvver heard of fuel coming from fuel system's charcol canister......its supposed to deal with vapor is it not..... have no idea what could cause fuel to come up there WOW.
Only thing i would have expected with that clogged is....... tank swelling..... or sucking shut....not sure which...... but basically a no run condition.....
One for the books
1 - 19 of 19 Posts
