So this week, my Malibu scared the crap out of me and is making me paranoid. The temp gauge climb to 5/8 (ish, slightly higher that the picture below) on the gauge with no check engine light. Usually, it sits a hair above center regardless of the environment. This is the first time this has happened. It even showed me "Low Coolant" on the radio but went away after restarting the car. So, I am thinking I am running low on coolant. Checked the overflow tank. At the full line. I check the codes and I get the following: C0561, U2100, U0073, U0101, U0140. All focused on a control module. I made it back home by having the heat on blast and it stayed centered the whole time. When I turned it off during the last 5 miles of driving, it got up to the attached picture (223 according to the code reader). Now, I live 40 minutes from any real town smack dab in between LA and Vegas. I will drive locally but only drive to Barstow maybe twice a week. I am about to default by taking it to the closest chevy dealer (65 miles away), but I wanted to see if anyone has any ideas. Bad module, bad sensor, flush to the cooling system?
The car has 150,500 miles, year old water pump, fresh oil change, etc. It has never caused me this kind of problem. I really only need to last 3 more months before I put it on a trailer and go back home to IN where I have my truck.
