Recently, I've been experiencing an unnerving 'steering problem'.
First, my car (roughly 31,000 miles on the odometer) has been trouble-free. I've been very pleased with the car. I'm a happy 'new' Malibu owner!
So . . . the 'steering problem' I'm writing about (and questioning) has to do with the electronic power steering. I've experienced, occasionally, the 'shaky steering wheel' while stopped, for example, at a traffic light. Seems like no big deal, and since it happens only occasionally, it's just a quirk I live with.
However, several days ago, while driving, I experienced (out of the blue) what felt like the steering wheel had 'detents' in it's travel on either side of the 'straight ahead / straight-line position. The steering seemed to decide on its own that we needed to be steering a bit to the right, and when I corrected by turning the wheel to the left a bit, the steering wheel seemed to decide (on its own) that we needed to be steering more to the left.
Each time I turned the steering wheel to compensate for the 'mis-direction', I felt a resistance in the steering wheel . . as though I was working against a 'detent' in the steering system.
Although the variation from left to right and back and forth that the steering wheel was moving was relatively slight, there was enough noticeable steering 'jolt' for my passenger (wife) to ask "What's going on? Why are you doing that?"
My 'gut feeling' is that this 'problem' is one of "electronics", and, sure enough, when I visited my dealership several days ago, nothing was found to be amiss. No "error codes", and the 'test drive' was "normal". "Power steering system operating as designed at this time."
And one more thing. Several times over the past several days, while stopped a a traffic light during one of these 'detent moments', there is a 'grinding noise' from the front of the car (while the wheel is 'deciding' which way to 'adjust' ['should I go a bit to the left or a bit to the right']. Several times (during a 'grind') I've put the transmission into neutral and slowly raised the engine RPM's hoping to experience a change in the 'grind'. RPM's seem to be unrelated other than making it more difficult to hear the 'steering grind'.
So, all you 'new' Malibu owners out there. Has anyone experienced a similar steering problem? It's an unnerving feeling to be suddenly fighting the steering wheel for 'straight-line' control.
