So a little backstory this 2.4 ecotec in my 09 malibu ltz I had just replace from an issue with my old motor timing jump and ended up cracking a piston head.
So I found a motor from a scrap yard from an 09 malibu that had been hit on the passenger side that the motor was confirmed to only have 103,000 miles on it.
I pulled the motor out of the other donor car, replaced the water pump timing/balance shaft chains, cover seals, vvt solenoids, vent-valve on the right side of the cam cover camshaft cover o-rings seals cleaned out the bottom end of the motor, ect.. So I then began to drive it.
After driving it I found that one day the car ended up getting a little hotter then normal, I noticed the coolant tank was low. I refilled it thinking it was just air in the system and it finally worked its way out. But I ended up having this issue again and now have parked it think don't need anymore issues and need to find the problem.
So I am investigating now what the issue is, I have so far done a compression test on each of the cylinders and I have starting at cyl 1 130, 130, 130, 140 . This is cold. When pulling the intake air handler I did also notice there seems to be coolant in the tube that the map sensor is housed. (found this odd)
Also ended up pulling the dipstick and finding coolant in the oil, this time that's why its parked. (milky looking)
Before I go tearing this thing down any farther to replace the head gasket, does anyone else have any other suggestions as far a troubleshooting?
