I just changed the head gaskets on the car after building it back up had idle issue after about 20 mins of car running. Idle jumps up and down between 500 to 1300 rpm. i found a couple vacuum leaks repaired those and it still idles rough after warming up and even rpm jumps while driving. checked fuel pressure it is at 40 pounds koeo and goes to about 37 with engine on. i pulled vacuum at regulator and pressure jumps to 47 but no fuel is leaking out of vacuum port could this be my problem?
I pulled the maf sensor no change. i am going crazy already lol
any help would be appreciated
thanks
thanks
