2002 Malibu 3.1
I'm new here, sorry if I didnt follow any rules correctly. I read them and think I'm ok. Ok so here are my trouble codes. P1122, P1189, P1626, U1000 and U1040.
As soon as I bought the car, I noticed that the turn signals would stop working here and there. I removed the dash panel and inspected the switch. It seemed fine, however the panel where it mounts was damaged. To be safe. I replaced the switch as well. I noticed also, the battery would be dead or very low in the morning. The odometer and display on the radio wouldnt turn off. I believe that's why it was draining. I unhooked battery and put test light between cable and post and pulled fuses until light went out. Honestly, I cant remember which. I let the car sit. I put the fuses back but decided to leave ground on battery unhooked so no drain would happen. I knew the ignition cylinder was the problem for odometer and radio displaybstaying on, so I went ahead and removed it, installed new ignition switch, cylinder and also, went ahead and got a new battery. After all this, I tried to start the car. It will start and run for 3 seconds. I posted a picture of the results my friends scanner got. I've tried to do the ignition relearn many, many times with no luck. I need some help figuring out what's wrong. I'm not the best at this kind of thing, but I can follow instructions well, and any help would be greatly appreciated.
