I have an '05 LS sedan and it has an annoying rattle which sounds like it's coming from the rear passenger side of the car. I've done some reading but haven't found anything worth following up on. I have GM full shop manuals and going into the rear decklid involves disabling the SIR so I don't want to fool around with the crash sensor in that area unless absolutely necessary.
I also noticed that some of the bulbs don't light anymore on my heater/temp/air direction controller board. The bulbs are not replaceable unless you know how to solder. I grabbed a new board from the wrecker and the same bulbs don't light up. Any ideas? I have a picture on my web page - go to the bottom and then scroll up. I have checkmarks on the bulbs that light up. I use the fan controller a lot because it allows me to achieve a lower idle when the fan is off and I'm sitting at a light. Yes, I'm a hypermiler.
http://75.152.215.111:8000/malibu/
