Gents; Working on my boy's 2005 Classic with the ecotec 2.2 engine with 140K miles. Changed the plugs oil and filter and did a transmission flush. Been an awesomely dependable auto for several years. The car is smooth and quiet but there's one annoying issue and that is a rough idle. Anything other than idle the engine is velvet smooth. It sounds like an egg beater at idle but wont stall nor hesitate on acceleration. I can feel the vibration when I put my hand on the valve cover at idle. The motor mounts seem ok...can't rock the engine....but with a vibrating engine not sure new mounts would smooth things out anyway. I don't want to throw parts at the car so I'm hoping one of u gents can lead me in the right direction. Hope all is well with all of you and thanks for any help.
1st. Definitely check the motor mounts.
2nd... its a 4 cylinder and its a GM 4 cylinder.
4 cylinders are naturally out of balance more so than other engines and vibrate a lot more.
I would for sure check the motor mounts tho. Does it do it when its in park? Does it only do it when its in drive?
Also when looking at the motor mounts, small little cracks in the rubber are ok. What you need to look for is completely cracked or separating rubber.
Another thing to do...requires 2 people...brake torque the car.
Put the car in drive. Apply E brake. Push down on the brake pedal and gas at the same and watch the engine with a helper. Do the same thing in reverse.
If the engine moves excessively when you brake torque then you definitely need new mounts
Sent from my SM-G975U using Tapatalk
