1 - 15 of 15 Posts
67245
67246
A few pictures of my recently purchased 06 Malibu SS. I’d love to post more, but sadly she’s in the shop for now. In the next couple months I plan on polishing up the interior, exterior and put some more power into this beauty. I’m relatively new to the car scene, so if one has insight on where to get started it would be greatly appreciated.
I would like to see a bigger picture of the dash layout.... to see the differences. ...i have a blue 06 3.5l 200hp malibu. My car personally has been a massive pain in the ass for me.... mayne you got a good one. There are some really big ....and common issues with these cars as you cam see in the threads bellow.....I am curious to see if they transfered to the ss version. Time will tell.
What motor is in it and whats the hp rating..... i thought i remember 240hp...but not sure.
When I get my car back from the shop, i’ll definitely post more pictures. She’s been a bit leaky. I don’t know the exact engine name but it’s a 3900V, I believe it’s 240 stock, but i’ve also heard from multiple sources it could be 250.
I found the 200hp to be great in this car.... yours should be .....funner lol . Ya 3.9L that a hell of a big 6 cyl. Well wish you the best on getting her fixed up....cant wait to see the pics
Dartz et al,
Yes, the 3.9l peaks at 240 horsepower. However... besides the 20% stronger engine, the SS also has:
1) Stronger suspension than the 3.5L model;
2) A heavier-duty transmission than the 3.5L model (to handle the higher power from the engine).
Because of these, the SS weighs 160 lbs more than your 3.5L model. On top of that, the SS has a hydraulic power steering pump (vs. your electric one), so the engine constantly has to use some of its energy to push fluid through the hoses.
Bottom line, a bigger engine in a heavier car is only a little bit faster than having a smaller engine in a lighter car.
Nice. Well i will say i love the highway milage of this version. Tis a shame about the issues i am having with mine and hope your SS is good to you
View attachment 67244 View attachment 67245 View attachment 67246
I own an '08 classic but the SS has always been my dream malibu
Dartz et al,
The tone of this post is bizarre, like it's trying to dump on the SS trim improvements. As if hydraulic steering is a negative (it's not) and the 3900 V6 power is cancelled out by 160 lbs and parasitic loss of the steering rack (also no).
Hydraulic steering is vastly preferable for the steering feel and handling characteristics, engine draw is negligible. The 3900 V6 is also a cool piece of pushrod hardware with variable valve timing and a powerband stretched out to 6200 rpm. Don't race the SS trim in an LT V6 unless you want to be sorely disappointed.
@Alan06
So, if the 200HP model could be boosted to 240HP and has an additional person in it, it would approximate the SS without that extra person.
The SS still wins. It doesn't take 40HP to move that extra person, so most of those ponies are there to move the car.
That plus a sportier handling package AND hydraulic power steering and it's a win-win-win.
Not sure of your failed logic, but we'll write it off to folks having opinions that don't always match facts.
The SS isn’t all it could have been but considering it originally cost less then the 200 hp LTZ version it’s a better starting platform then my ‘05 3.5L.
SS is tunable (unlike the ‘05 3.5L) so you can get a few more hp out of it if you want to spend the money.
Only suspension changes between the 3.5L and 3.9L is the strut tower brace and thicker sway bar and end links in the front.
The gear ratios are slightly more aggressive 3.69 SS vs 3.05 3.5L in third gear, +17.4%.
However the wheel & tire diameter is larger as well 775 revs per mile SS vs 818 revs per mile 3.5L, -5.3% which hurts acceleration.
Now I run a smaller tire size of 837 revs per mile on a lightweight 16” wheel to give better acceleration.
The simple change of lighter 17” wheels and smaller diameter tires would make a significant improvement in acceleration.
cp-the-nerd and DrivenDaily,
The point of my post was to answer Darthz's valid question and to give him some facts (not opinions) about the differences between the different Malibu models. Neither of you bothered to answer his questions, yet you both took the time, two months later, to assume I was trying to "dump on the SS trim" or confuse DrivenDaily with math and logic.
I apologize if my post was too technical for the two of you, since everything I wrote was, unlike your responses, factual and completely un-opinionated. Or perhaps my post wasn't technical enough? Without more hard data, maybe you both assumed I was merely giving out opinions, which led you both to do the same. If so, I apologize for my lack of data. Allow me to go into more details.
If you could remove the 200 HP engine from an LS model and replace it with the 240 HP engine from an SS, you would not have an SS model. You would have something faster than the SS model! Just because the SS model's ENGINE is 20% more powerful, the CAR is not 20% faster. Here's why:
1) An old rule-of-thumb when modifying a car's weight vs. power is to assume each 10 pounds gained is the equivalent of 1 horsepower lost. Since the SS model weighs 160 pounds more than the LS model, that's the equivalent of having lost 16 peak horsepower. That would be like having an LS model with an engine that peaks at 224 HP.
2) The power needed to pump steering fluid through the hoses and piston can vary from 4 HP to 7 HP, depending on the size, the engine, the speed of the turn, etc. My point is that the SS model's steering pump is ALWAYS drawing some of the power from the car's engine. Even when the SS is driving in a straight line and isn't making a turn, something is providing the energy needed to make the fluid circulate around. That energy isn't free.
But since the LS model has electric steering, it ONLY draws some of the engine's power during turns. When the LS model is going in a straight line, no power is being taken from the engine.
I'll assume just 2 more horsepower is needed to keep the average SS model steering system running than to keep the average LS model steering system running. It is a small amount, but it is still a difference between the two models, which is what Darthz was asking about in the first place.
That brings the power difference between that two models down to the equivalent of 200HP (LS) vs. 222 HP (SS). That's an 11% increase in peak horsepower, not a 20% increase.
Some responses to Drivendaily:
"The SS still wins."
Yes, you are right. Neither I nor anybody else ever said otherwise. My SS still has the equivalent of 11% more power than the LS.
"...It doesn't take 40HP to move that extra person, so most of those ponies are there to move the car."
Right again. And we see now that "most of those ponies" equals just 22 horsepower. Not a huge improvement over the LS, but is IS an improvement.
"...a sportier handling package AND hydraulic power steering and it's a win-win-win."
I agree with your opinion about my SS model's handling (I gladly accept that weight vs. speed trade-off), but I'm not sure about the power steering. Especially since some engineer at GM messed up by running one of the hoses directly over the hot exhaust pipe and thinking that wrapping it in aluminum foil is going to keep it from burning through the rubber. Many of us have had to deal with that burnt-through hose and steering fluid leaking out under the car. That wouldn't happen with electric wires and motors.
Also not sure where your third 'win' comes from.
"... folks having opinions that don't always match facts..."
How right you are.
@Alan06
I think you misunderstood my post.
While I did needle you a bit, it was only to make the point that having an SS with sportier handling is a win. That's one.
Having 240 HP is a win. That's two.
Having hydraulic PS is a win. That's three.
Let's not debate who's silly about math and logic. Mine was not faulty, nor am I confused.
I didn't answer Darthz's question because he asked about the motor and someone answered him fully. The tone of your first response was bizarre, and now you're blowing enough hot air to affect global warming. It's funny to me you'd make a point about my reply being 2 months after yours. Care to look how long its been now that you're responding to it? :ROFLMAO:
Where exactly did you pull that arbitrary calculation that 10 lbs cancels out 1 hp? That's nonsense, my car's power to weight is just under 10 lbs per horsepower and I have a Corvette engine. The Malibu SS is probably around 15, making your rough estimate about 50% generous. Lmao. You apparently have the curb weights, so why didn't you just calculate pounds per horsepower?
Condescending seems to be your modus operandi, but you just look awkward throwing bad math around. The SS trim offered better handling, steering feel, and acceleration than other gen 6 models, end of story.
Oh look, Car & Driver has archived reviews of both the Malibu Maxx LT and Malibu Maxx SS.
Malibu Maxx LT
200 hp/220 tq
3460 lbs
0-60 mph: 7.8 sec
1/4 mile: 16.1 @ 86 mph
70-0 Braking: 191 ft
Lateral grip: .78g
Malibu Maxx SS
240 hp/240 tq
0-60 mph: 6.9 sec
1/4 mile: 15.3 @ 91 mph
70-0 Braking: 177 ft
Lateral grip: .83g
In the car enthusiast world, if those two were cars competing in a comparison test, it would be considered a crushing victory for the SS. I spent around $1,000 and put a ton of effort toward making my 2009 Malibu V6 faster and handle better with enough success that you could easily feel it from the driver's seat, yet I made maybe half the improvement in acceleration and handling that the SS trim did above.
According to Edmunds, after selecting the correct engine size and selecting "Specifications", its curb weight shows as being 3620 lbs. Source
I've put a few handling/performance bux into my 2011 3.6L as well.
Most of the effort in dollars was for HP Tuners to be able to manipulate the specs. Of those, the transmission shifting strategies were what were massaged the most. I didn't do it; I got a copy of the file from @cp-the-nerd and gleefully fed it into my car.
Next in dollars was lowering it 1.4" with Eibach springs and up-level front strut inserts.
Last was lifting the rev limiter a bit to keep first gear from hitting it before shifting, plus taking about 75% of Torque Management out of the picture to get faster, snappier shifts.
1 - 15 of 15 Posts
