I am wanting to replace the right front hub on my 2006 Maxx LT (3500 V6). I had everything removed, all bolts from hub removed, axle shaft splines off the hub etc. Is there any alternative to getting the hub off, without having to spend big $$$ to rent a puller?? I do not have access to torches, or air tools as I live in an apartment. Could a chisel be used? Hub has been on a LONG time
Thanks in advance
Many auto parts stores will "rent" you the tool for free. You "buy" it, including normal tax, use it, then return it and get all of your money back, including the tax.
Big freaking hammer and beating it off is the alternative. At least a 3 lb. one. Been there many times.
