I’ve just recently started driving my girlfriend’s Malibu with 268k miles on it and it sounds horrible. I ran a code scan and it came back with a POO16 so I picked up a new camshaft position sensor and tried to Google the exact location to install but I’ve found like 10 different answers that all contradict each other. She had the timing chain replaced previously but it still has trouble starting every other time or so, has no get up and go, and at idle sounds like it’s ticking and chugging. I refuse to pay a couple hundred dollars for something I should be able to do in 5 minutes. I just need a map.
I believe there is some confusion here. The CRANKSHAFT position sensor is BELOW the oil filter.
The CAMSHAFT position sensor is ABOVE the oil filter.
Easy to get the two mixed up.
Also, in most places that I've seen, the crankshaft position sensor is CKP, and the camshaft position sensor is CMP. It's different by only one letter, but electronically they are different.
