Crank no start!!!! Crankshaft position sensor circuit.
To start off originally had four codes for intake and exhaust camshaft actuators and crankshaft performance. Both actuators checked out so I said let’s see what replacing both sensors would do. Now 3 codes went away which was for the intake and exhaust actuators and the crankshaft sensor performance went away now only code staying is crankshaft position sensor performance. Have my car stuck still will not start what else could I do, the connector on sensor itself had 2 pins reading about 5 volts with the key turned to the on position and it had a good ground as well any ideas of what else to check? need to get car started
