We have a 2010 Chevy Malibu 4 cylinder that has an electrical issue i'm tired of throwing parts at. Anytime your driving the vehicle around and decide to turn on the A/C it will eventually throw a p1682 code forcing the car into engine reduced power mode, making the vehicle run terrible so you have to pull off to the side. If you clear the code and start the car back up it will run just fine. Also if you never turn on the A/C it wont throw that code again. I've also noticed if you turn on the A/C that cooling fans will turn on as they should, but once you turn off the A/C the fans will continue to run and after a little while it will throw the p1682 code. So that rules out the idea that maybe my A/C compressor is bad, forcing the serpentine belt to slip, causing my alternator to not charge properly, making the computer see the voltage drop between the two ignition wires its monitoring. I'm stumped on this one.
So one more time, p1682 only activates when the A/C cooling fans are running (not immediately, but it eventually will, its mostly a guessing game). We've already replaced the cooling fans even though the code is related to a voltage difference between to ignition wires.
Any suggestions or comments are greatly appreciated.
