I'm going to try not to be long-winded here.
My car occasionally needed a jump for the past 6 months (just shy of 90k right now) so I'm considering battery replacement anyway. Take the battery to auto store a block away, tests out at 10V, i walk away with a replacement.
I may have accidentally hooked it up backwards for about 1 full second. this was enough time for something underneath the engine (not in the fuse box next to the battery) to spark and throw a little smoke.
Well, sh*t. I noticed that i did something very stupid and proceeded to hook them up properly. Car starts up but the battery light is on.
Engine is running fine, belts are turning, but multimeter registers less than 12V at battery connections while car is running, suggesting alternator not charging.
Take the alternator to the same auto store, tests okay. Twice.
Youtube video guy says original alternators sometimes test okay but in actuality are not functioning properly, so i replace anyway.
I hook the new one in, connections are all good, car starts up just fine.
I still have the battery light on - and battery posts still register just under 12V while car is running
Look for fusible link between alternator and starter that maybe fried - but it's just a solid wire running between, no fuse or link of any other kind.
Removed harness from alternator, connection looks okay, registered .7 ohm (honestly don't know what that's supposed to be, but it seems fine?).
What else could i have caused that would keep the battery from being charged by accidentally (and very temporarily) reversing the polarity?
