1 - 12 of 12 Posts
2010 Chevrolet Malibu
I have a bit of some front end noise on the car
If I sit there in a parked spot and turn the steering wheel it sounds like it’s rubbing on something
I’ll make a video of what it sounds like and post for anyone to see if they can help out
thanks for the help in advance
Sounds like the spring is twistin' a bit on the struts, or the upper strut bearing is lettin' ya know it needs some attention.
Thanks for your input I appreciate you always commenting on my stuff
I’ll keep it parked until I can get it to my mechanic for a look and see what’s up
That little bit of noise is probably not gonna be an issue if you wanna drive it, but use your best judgment regardless.
I’ve got a second vehicle that needs to be used haha parked to long so I’ll just drive it
Discussion Starter · #7 ·
One more question
how do I know If my power steering is electric or not
2010 2.4cyl LS
Gen7 2.4L are all EPS. 3.6L V6 are all hydraulic. Not sure about the 3.5L pushrod V6 - I think it's EPS.
Another way: pop the hood, lift the fuse box cover (under the battery cover). On the end closest to the firewall will be an 80A fuse for EPS. Also while under the hood, if there is no obvious PS pump with a twist-off cap, then it's EPS.
Discussion Starter · #9 ·
Thanks again
Yeah I figured after looking around that it was eps
the reason I asked is because I thought maybe low on ps fluid but like you said maybe I need to change out the strut / spring etc
I’ll get it looked at tomorrow
thanks again
You have the best advice
Thanks again
thanks again
Nah, I don't, really. A lot of what I share has been gathered from others who know way more than I do. Without this forum I would not even be aware 3/4 of what I've heard. The guys who need the kudos are the ones who dig deep and share from years of experience. I just babysit the site.
Since your in a salt zone my money's on rusty struts and springs.
Reactions: jonolach
Discussion Starter · #12 ·
I just got the car safetied 2-3 months ago and my mechanic said everything looked good
replaced the control arm bushing and rear pads and rotors
Other then that he said all looked well
1 - 12 of 12 Posts
