I've been searching the net for help, a lot of people have the same problem but nobody has posted if they ever found a solution, No codes, fuel pressure is 55 psi, new cam sensors, (both) it starts and runs a few seconds and then stalls, I unplugged the intake cam sensor and it starts and runs fine but it will throw a po340 code after a while of running, if I plug the sensor back in right after I start it then no code, it will also start right up when I shut the engine off and immediately restart the car, but if I wait a few seconds it will start and stall. If the crankshaft sensor was bad it should not start or am I wrong about that. I really do not want to keep throwing parts at it. any help would be greatly appreciated. Thank You
Discussion Starter · #2 ·
just a update, I found the problem, it was a bad crankshaft sensor, now it runs fine. I guess that the engine can run with only one cam sensor working, Thanks for all the help! You guys are the best!!
