I have a 2011 Malibu LS 2.4L. It would crank but not fire. Pulled the fuel pump relay and put back in and was able to get it started and drove to shop. They replaced relay and started fine. Took home and it wouldn't fire again just crank. Pulled fuel pump relay out and it started and then died. Put relay back in and it started up. Took to shop again and they removed and replaced fuse box in the trunk. They said the fuse for the defrosters was melted. Again started up at the shop and brought it home and after sitting overnight it wouldn't start in the morning. Since then I can get it started by pulling the fuel pump relay, starting it (then it will die), replacing the relay and it will start and then run. I can then drive it around and turn it off and it will start but after sitting overnight I have to pull the relay again. I have put more money into it than I would like already. If the fuel pump needed to be replaced I wouldn't think it would start up at all? Could it be a short? If so how would I go about finding it?
