Any fuel smells around the car or in the oil? Any hard starts when the engine is warm?
that’s exactly what I was thinking was the problem abd s as knits pukled the trigger on the part but so many people (including mechanics) were sayin no it would definitely throw a code. Like there was no way it was possible. Thank you for confirming my thoughts . That’s definitely gonna be my next step#1 O2 sensor, the one in the exhaust manifold. That is what monitors fuel mixtures, it may be on the edge of failure or getting weak but not bad enough to set a code.
When I changed the O2 sensors in my Tahoe I got back 2 mpg highway on it, no codes, scanned fine and it ran fine on the old one.
2 mpg is a big deal on something that only gets 18 mpg highway normally.
Use only a AC sensor also, aftermarket ones known not to be reliable.
****UPDATE changed out my 02 upstream sensor and when I pulled it OH MY GOSH. Completely warped !(attached photo) I don’t even know how the damn thing was running still. Went on a road trip the next morning and went from 15mpg to 22mpg 🙌🏼 The only problem is that the check engine light came on after a day then turned off after a couple hours then back on agsin. Luckily there was an O’reillys near by. Used their scanner and it said that it was running lean ??? Over the next few days it would come on and turn off but no other problems and maintained mpg. It has been off for a couple days now. Could it possibly be the downstream now?#1 O2 sensor, the one in the exhaust manifold. That is what monitors fuel mixtures, it may be on the edge of failure or getting weak but not bad enough to set a code.
