1 - 8 of 8 Posts
Please help. My 2011 Malibu has 160k but has only had minor issues. Every time I think it’s fixed, this happens again. I have narrowed it down to specific conditions.
Outdoor temp has to be close to 80° or hotter. More likely to happen when A/C is running.
When car is stopped or barely moving, reduced engine power, shaking and stall.
Will start right up again after about 1 1/2 hours. (assuming after engine has cooled down)
Throws P1682 code, Ignition 1 Circuit 2.
Replace the powertrain relay. Look for heat damaged prongs on the old relay and if so fuse block may need a good inspection.
I’ll put in a new relay today and let you know. We did pull out the fuse block and inspect for anything looking amiss or burnt to no avail. Every fuse I pulled looked great too.
Discussion Starter #4
Well, I will have to order the relays.
I did see that all the prongs on fuse junction block in engine compartment are clean. However, prongs on majority of fuses in internal and trunk fuse junction blocks are brown even they test good. Is that an indicator of anything?
Discussion Starter #5
So ran the car in driveway with no issue for 35 minutes today with outdoor temp of 80°.
Turned on the A/C and instant vibration and variance in rpms. Turned the a/c off, stayed a little shaky. Turned a/c back on and it tripped the reduced power & crazy shaking.
Has the throttle body been cleaned ? That could be one of your issues. Bad compressor could be a issue also but you did have a code set.
Fretting corrosion is a issue in this gen. of cars, read the sticky on it and use a electrical contact cleaner/protectant on all your module connectors.
P1682 CHEVROLET Meaning
There are 2 ignition 1 voltage circuits supplied to the Engine Control Module (ECM). The first ignition circuit is provided by the powertrain relay, through a fuse. This ignition 1 voltage circuit supplies power to all the internal ECM circuits associated with the throttle actuator control (TAC) operation. The second ignition 1 voltage circuit is supplied by the run/crank relay through a fuse, and is used to power the remaining internal ECM circuits. If the ECM detects a voltage difference between the 2 ignition 1 voltage circuits, DTC P1682 will set.
Discussion Starter #7
Sorry, I’d didn’t include in my op- 2011 2.4 gas
Have not cleaned throttle body. We tried swapping relays in the engine compartment box and could not get problem to jump.
1 - 8 of 8 Posts
