Bought a 2011 and it comes with a keyfob. When you use the key to unlock door the alarm or panic goes off. Anyway to turn this off? This is with fob in the attached to keyring, did not try with fob not in area.
Thanks
2011 does not use a presence-detection keyfob. The fob is a simple design: press the button, stuff happens.
If the doors are locked using the fob, then opening the door without the fob will sound the alarm. That goes for reaching in an open window and pulling the lock knob up, using the interior switch, or by inserting the key in the door.
