Any Gen7 engine should fit, but beware. When I bought my 2011 3.6L V6 in 2010, it later developed a knock that turned out to require the dealer to overhaul the engine. The number of teeth on the crank had been changed, so the first crankshaft they got was wrong and they had to specify a different one.
If yours is the 2.4L, which it sounds like it is based on you saying "head" and not "heads", it might need the same attention paid to what you get.
You can call a dealership parts department for some guidance. After you pick yourself up off the floor at how expensive an engine is, you might have more info to help you along the way.
