Was intermittent & has become more constant.
Volume up does volume down
Volume down does preset up
Preset up/down operate as normal.
Used to be able to mute with the voice control button & it would resolve, but this doesn't seem to work anymore.
Cruise control side all works as normal.
Possibly unrelated, but part of the column, I usually don't get the first audible 'click' from the blinker unless I've used the blinker shortly before.
Discussion Starter · #2 ·
Bump, no simple solution for this?
Adding to the symptoms, the intermittent wipers seem to have random timing, regardless of which setting it's on. From really long delay to almost constant [low] with no delay.
Check this thread to see if it is helpful. It just might be dirty/corroded connections at the plugs.
To service the SWC switches, you will have to remove the air bag, which is a PITA. But I'd try the ideas in the thread first, since they're nearly free, pretty easy, and guaranteed not to cause more issues. Heck, they might even fix 'em!
Thanks, I'll give that a shot since I'll be home for the next few days.
Hopefully I don't have to do anything involving removing the airbag or wheel. I can just deal with it, if that's the case.
Minor irritant for a 10 year old car, even with <90k on it.
