2012 Chevy Malibu
My 2012 Malibu air/heat will not power on. It’s not a fuse, it has something to do with the panel under the passenger side glove box. I use to be able to wiggle the wires (the yellow one) and it would cut on, but that no longer work. Helpppppp!
Does it have Auto Climate Control or the manual version? Only the LTZ has the auto.
You can see why we have the following request already prepared.
If you turn the speed to High, it will bypass the resistor pack.
If you still have to wiggle the wires at the blower, then you may need a new blower. You may also need a resistor pack, but you need to test both before just replacing either one.
