Shop manual subscription to alldatadiy.com would be a wise thing to do. It's cheap enough. And a good scan tool.
|Code P0697 Chevrolet Tech Notes
Disconnecting one component at a time from the affected 5 Volt reference circuit while observing the scan tool 5 Volt Reference Circuit Status parameter may help locate the fault. The scan tool parameter will change from Malfunction to OK when the source of the fault is disconnected. If all 5 Volt reference components have been disconnected and a fault is still indicated, the fault may exist in the wiring harness.
The 5 Volt reference 3 circuit provides 5 Volt to the following sensors: (Some models may have different sensors, please consult the factory service manual for the list of sensors for your model and year)
- Accelerator pedal position sensor 2
- Manifold absolute pressure sensor
