Problem has been SOLVED. It was a fractured resistor at location R203 on the circuit board that makes up the Instrument Cluster Panel (ICP). This problem seems to be common on 2013 to 2016 Chevy Malibu Limited(s). I found the following link (YouTube video - How to Repair a Chevy Malibu Cluster) when searching on-line and sent the ICP to him to fix.
He did so, sent it back, and I installed back into the car and everything now works. He charges $100.00 + return shipping to fix. My cost was $25.00 to ship to him via UPS and he charged just under $112.00 which included return shipping via USPS. So my total cost was under $137.00 (appears that it would have been less if I used USPS to ship to him), which is a lot better than paying over $800.00 to have the dealership replace with a new one. So, it is well worth your time to watch the video and you can get an email address from it to contact him.
I also used what I learned in another link (YouTube video - 2013 Chevrolet Malibu Remove Instrument Cluster), to learn how to remove the ICP. It is pretty simple to do, but be advised, that in the video, he already has the parts he is removing already partially removed. I learned, while actually removing, that I needed to pry, with a tool made for the removing trim and molding, the lower piece on the right side of the steering wheel. The only other obstacle I encountered was the hump that covers the top of the ICP. I was able to use my hands to pry away from the ICP. All of the molding is inserted with clips that go into slots, so you will have to pull, towards yourself, these pieces to get the clips to release from their slots. The last bit of advice I have, is to disconnect the battery before removing the ICP, this is just a precautionary step.
There are other places that do this kind of repair. But I can attest, to the guy in the first YouTube video, that he can fix this problem and at a reasonable cost. He told me, his turnaround time, after he gets the ICP, is 4 days or less (not including shipping time). I hope this helps others, and I do believe that Chevrolet should perform a recall on this, as it appears they use a different, weaker, type of solder that eventually malfunctions.
