These were working fine until now when they are greyed out. I can't get any of those 3 to turn on by pressing them. So, is there a way to reset to defaults in the radio to see if they will magically start working? I think it's way to expensive for me to get the dealer to replace the radio.
Please help!
Thanks!
I don't know much about it, but I've seen other threads here about the radio needing to be programmed with some radio code? I think it can be added at the touch screen if I remember correctly. Don't trust my memory, but search around on this forum and possibly you will find the threads.
This is not the one I was thinking of, but here's a thread where the is some discussion that may give you some clues: Radio Locked
Also, my meter with the GM package has a radio section. Never looked at it too close, but I'll check it later to see what codes and options are available.
Do you have the radio turned on with the big power button? I know i have done that a few times...
I did check my meter and there is a section for "radio", but even though there are some items there I can control, does not look like I would be able to reprogram the security key. I think other posters are correct here, to get the radio reprogrammed is probably a trip to the dealer.
I have a 2013 Bu LT My bluetooth just stopped working a couple months ago. I've done everything the book says and tried trouble shooting. Any suggestions?
