2016 Malibu 1.5l LT Choppy engine speed when at idle and low speeds
5586 Views 5 Replies 4 Participants Last post by  cp-the-nerd
My Malibu has had an idle issue where when i stop in drive the engine will seems likes its misfiring and the engine speed will go up and down about 150-200 RPM. This only happens when the engine is cold. Just today i experienced the same thing but at around 30mph and it kept doing it as i came to a stop. I also feel as if sometimes the engine will have reduced power. I drive the same way every day for work and with cruise control set only some days will it downshift on that hill and sometime it wont. Usually around 50mph every time.
Any help would be appreciated.
2016 Malibu 1.5l LT - 73,000m
Howdy and welcome.
What maintenance has been performed on this car other than oil changes? No warning lights/messages I assume?
Howdy and welcome.
I changed spark plugs about 8,000 miles ago.
I changed transmission fluid 3,000 miles ago
Only check engine light ever posted was for downsream O2 sensor back when i put crappy Fastrip gas in it. That was at around 20,000 miles. Trouble free until now.
Pulled plugs and did a compression test on cylinder 1. The one know for cracking pistons and reading was good. But did notice black soot on the number 1 spark plug. So it is definitely running rich, just don't know why.
I believe im having a similar issue, did you ever figure out what was causing the "richness" in piston area.
Running rich with rough idle is a strong sign of carbon build up in the intake ports and valves.
