1 - 8 of 8 Posts
Hi I have a 206 Malibu ls my code reader is saying my engine oil pressure Control circuit is stuck on, is that the oil pressure sensor and if so does anyone know where it is exactly
The code is Engine Oil Pressure Control Solenoid Valve Stuck On. It's either the sensor or the control solenoid valve.
Sensor is under the starter and solenoid valve is under/inside the lower oil pan on a 2016 LS.
The code is Engine Oil Pressure Control Solenoid Valve Stuck On. It's either the sensor or the control solenoid valve. Sensor is under the starter and solenoid valve is under/inside the lower oil pan on a 2016 LS.
Thank you, by chance did you have this problem as well and if so what were the symptoms?
1 - 8 of 8 Posts
