That looks like it took a long time, but was most likely a labor of love.
Does your car have ANC, and if so, did you do anything special as a result?
I assume if you paid for access to the same service manual site you could get the necessary diagrams.Does anyone have the wiring diagram for Bose set up. I've looked everywhere and cant seem to find it. Trying to add a line converter to add subs.
.Sent from my SM-G950U using Tapatalk
Yep, grew up here, left for college and accidentally came back to work here..
I was admiring your Honda Accord pictures, I like your thread and your expertise. I noticed the Lujack dealer tag on your car.
Are you a Quad Cities resident?
What would be the best way to tap into these wires? Can I use a t- connector or is there something better? Sorry I haven't done this in a long timeCorrect, the output I measured from the HU is low level, not speaker level.
From the graphs, I didn't measure any bass attenuation as volume increased.
Sent from my SM-G900V using Tapatalk
Soldering connections is the only recommendation I have, and the only way I tap wires. Anything other than soldering will be problematic. Wires don't need to be cut, you can strip back insulation and solder onto the wire, then tape up (3M Super 33+).What would be the best way to tap into these wires? Can I use a t- connector or is there something better? Sorry I haven't done this in a long time
Thank you for your helpSoldering connections is the only recommendation I have, and the only way I tap wires. Anything other than soldering will be problematic. Wires don't need to be cut, you can strip back insulation and solder onto the wire, then tape up (3M Super 33+).
I have videos showing connection methods:
Soldering is best if you are good at it. But using pigtail or twist crimp connectors should be plenty good enough for the car's lifetime.Soldering connections is the only recommendation I have, and the only way I tap wires. Anything other than soldering will be problematic. Wires don't need to be cut, you can strip back insulation and solder onto the wire, then tape up (3M Super 33+).
Yep, this is why I measured it. I suspected the same and was happy with the signal level.
I am disappointed with the factory EQ and will have to correct that with the new system.
What did you tap into to get the remote wire so the amp turned onSo everything works fine. New amp took care of my issues. Don't buy Rockville (Amazon) amps, they are junk. Everything works perfect and no ANC issues whatsoever.
Was you able to do anything to tone down chimes, I have same problem with being loud?Yes it is, all the output is coming from the H/U to the factory amp. I have a 2016 LT with a 4 channel amp and processor connected from the factory amp....suffering because my chimes are LOUD! One installer said he can somehow bypass only the speaker outputs from H/U to my 4 channel amp.
