2018 Malibu brake booster sensor P0558 wiring?
3.6K views 2 replies 2 participants last post by  slacorte
Take a look at this - very possible something is flipped because these diagrams have conflict in pin position. Picture uploads weren't working very well last week so if this doesn't work... let me know and I'll figure something out.
Also, I see a rodent messed with wires. If you are not 100% sure of that or you have repaired the wiring and you are still getting ABS activation noises and that code inspect the vacuum pump. They can seize, reducing vacuum and causing issues with the brake booster and that is one of the codes. If the vacuum pump breaks up it can cause some major damage.
