1 - 8 of 8 Posts
I have a 2019 Chevy Mailbu LT that just hit 41,500k miles on a roadtrip i was on this week and this car had given me no issues really and has always been solid and mid roadtrip i had a tire air pressure sensor go off but the tire pressure was normal? i was mid roadtrip when this happened and i just got home yesterday driving 600 some miles with this light still currently on. i added air to the tire this morning to make it 30PSI and it is still on!):
What is the recommended pressure on the inside driver door label ? 29 seems low to me.
After adding air sometimes they need to be driven so sensors reset.
Most gen9 are 35 psi cold, some hybrid owners reported 38 on the sticker. Those tires showing 29-32 going 83 mph are way under, more like 27-30 cold.
I like 33 a lot more than 35 specified in my 2016. 35 gives me uneven treadwear in the center so I use 33.
Make sure it is 33 cold, not when you get air away from home as the tire warms while you drive and pressure increases. I don't know about that honking stuff, that's weird - but heck I didn't even know 19s moved to 33 psi.
Maybe it's a new feature letting you know your at the recommended pressure and not overfilling at those cheesy air stations we have today.
2019 Chevy Malibu LT
and when i tried refilling tires when the back got to 33 the car not kidding starting blicking the turn signals and when i got to 33 on front tire the car honked at me!😂
The turn signals are suppose to blink on the tire your filling. If a different signal is blinking it means they did not reset them when they rotated your tires. Also, the horn honks when you reach the correct psi to prevent over filling :)
1 - 8 of 8 Posts
