1 - 14 of 14 Posts
2019 Malibu LT w/ 1.5T
Having an intermittent issue. Every now and then, car will be extremely laggy taking off and going through the gears. So bad that at like 60% throttle it takes forever to get up to speed. Then the turbo will light and it will set you back in the seat, but once it shifts it falls on it’s face again. Then when you shut it off, the engine fan will run for 15-20 minutes. After it sits over night, it runs great for an hour or so, and then will start the issue again.
Has anyone had a similar issue? Car is at dealer now and of course they can’t get it to replicate the issue with how little they drive them.
It can be tough when the behavior is so intermittent it doesn't happen at the dealer. There is a bulletin and ECM update specific to 2019s that states lack of power and hesitation on take off with or without a couple fault codes. A similar issue occurred on 2018s; those owners offered a similar description has your description. Dealer should check on it. Here is that bulletin:
Bulletin 19-NA-058
Greetings All,
I just purchased a 2019 Malibu LT, Certified Pre-Owned Vehicle about 2weeks ago. I am now experiencing the very same symptoms.
Appreciate the insight!
Greetings All,
Hello Again!
After creating a Service Appointment Request, via my handy, dandy MyChevrolet App, I took my Malibu into Service. I provided the information, as contained within this helpful thread, as well as the TSB Number for their reference.
I'll keep you posted on the outcome of the appointment.
Vehicularly Yours,
@Bow-tye-Timothy_1970 does your car accelerate properly now? Let us know if you are satisfied with the fix.
Greetings @cp-the-nerd!
My apologies! Yes and yes! The recommendation made by @campb292 resolved the issue, and I am completely satisfied with regaining my MPG and performance.
No apology necessary! I was just curious how it was working out for you. Thanks very much for your responses here on the forum! We hope to see you around.
Hello Again!
Vehicularly Yours,
was this something that was covered under warranty? if not was it expensive ?
I'm not who you quoted but I'll answer. If you have a 2019 and the problem described in this thread and the corresponding bulletin, GM is covering it for 8 years/80,000 miles (USA).
Reactions: Gail whitt
Curious if this would explain what is happening with my 2019 Malibu LT. Recently when I come to stops and Auto Stop kicks on my car will just shut off when I try and accelerate too fast. Anybody have an idea or the same issue? I recently had the charge air cooler duct and the throttle body replaced from a recent recall.
1 - 14 of 14 Posts
