Has anyone done a drain and fill on the 9 speed? I see a guide for the 6 speed but nothing for the 9. Is it basically the same thing?
Thank you this is exactly what I needed to know.From what I see it is pretty much the same. The difference will be accessing the fill plug. Can you see it and reach it? The 9-speed uses the same dexron-vi fluid so check for that license on the product you use.
Here is a video that shows the basics - different vehicle but similar unit. Looks like it was overfilled at some point as there is blow out all around the vent cap. Don't do that, just measure what comes out and replace the same volume. There is no "add an extra quart for more speed" here.
Noted, just have to see how I feel that day. I did all that including temp and leveling on the Navigator, but you're right it is alot more trouble.I've done a few no dipstick GM transmissions fluid changes in the family fleet. Unless it's got a large leak, not just a damp spot seepage, I just drain and measure and refill with the same amount. I will put a couple extra ounces in but no more than that.
Level plug checking is a bear without a lift. Working with it hot and getting the vehicle level without a lift is not worth the aggravation.
