worked perfectly last month, had to take it off the road for a little, but ran it here and there, any idea where to start? could it have to do with some tampering with the bcm in order to bypass the drl ?(which i didnt get to work because i couldnt find proper info, all wires are back where they belong)
· CMF Veteran Member
Welcome to the forum.:) Please explain what you mean by "idles wierd." Both the BCM and PCM have circuits that run on the battery voltage and 5V TTL level. You may have fried something by creating a short between the two voltage levels. When did the problem start in relation to your BCM adventure and what exactly did you to the BCM?
