1 - 11 of 11 Posts
Trying To get LTZ fogs put on my LT but cant seem to find the whole housings anywhere...Does anyone know where to get em??
Thanks in advance
You can get them from any Chevy dealership, or you can google "GM parts" and you will find dozens of sites selling parts.
You can even search here for the info, and the problems you might encounter installing them.
I got some off ebay for about $30 each but that was just for the grills. I have yet to get the actual lights which are on Ebay for about $50 each, then you need the wiring kit (I think this one will work): http://cgi.ebay.com/ebaymotors/Chevy-Buick-Pontiac-Saturn-Fog-Light-Wiring-Harness-_W0QQcmdZViewItemQQhashZitem230adce4cdQQitemZ150506104013QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I did put the grills on and just covered the holes with black duct tape so its not just a hole and I love the look. That's the only reason I got the grills actually is for the look. Someday I will add the lights but I just haven't found the extra $200 that I will need to complete everything.
ok cool, thanks everyone...im going to look into it
Does anyone here know how to install them ?? i have all the parts and searched many times , people talking about but never anything that i can find how to wire them up. I got the factory switch and all housing bulbs etc. just need a little help. Any would be great.
· CMF Veteran Member
Hmm, that's not too helpful. You say you "have it all installed" and then " just need to wire it up." Unless you're missing some component, it should be plug-and-play plus a visit to the service department.
Not plug and play on my car. No stock wiring for the fogs exist. Gm had my car torn apart looking for the (Plug and play) not there. There is no wires ran to correct pins on the bcm an from the fuse box underhood there is no wires for the correct rely wiring either. Thats where I'm stuck at trying to figure out how to wire the stock switch up. I bought all the pigtails for the correct wiring , just need a hand figuring it out.
I'm sorry I wasted your time.:( What I'm getting is, you want someone to help you wire things up outside the factory setup. If another member doesn't jump in here, you may want to start a new thread with enough detail so someone can suggest an intelligent solution. Do include an inventory of "all the parts" as well.
I'd be happy to take a stab at helping you, but like SS says, tell me what is installed and any wiring you may have hooked up already.
When I had my '09 I installed PIAA driving/fog lights and used the blank filler next to the dimmer to install my switch, then ran wires out to the relays. Worked perfectly and automatically.
Also let me know how you want it to work so I can design the circuit the right way.
Pictures would be helpful as well, but not absolutely necessary.
1 - 11 of 11 Posts
