Ouch!!! DOA, toothpaste on the lights
NXT is all you need on the headlights
never heard of TP on headlights, do you use paste or gel, some pastes can be really gritty.
Actually I can't find the link anymore, but I was reading once, and tried it out and it worked quite well.
You are correct TP is abrasive, HOWEVER it is not so abrasive that it will scratch the lens if applied "gently" what it does do is it helps to fill in scratches better than wax does on headlights. I don't know all the technicalities on this, but on my previous 05' GP the headlight's were getting really bad from all the highway driving I did so I gave it a shot and low and behold it worked really well.
Just apply by hand, not with a power waxer, and buff off. I used to do about 3 coats of regular TP not gel, and it would work quite well.
Just some food for thought!
OH on this topic of maintenance....
What do people use for power waxers?????
I have a 10", 12" and 6" I use. I apply with the 10" and buff out with the 12" BUT for the sides of the car I use my 6" and change pads. I have the side body mouldings and using a 10" or 12" is just too cumbersome, and I find the 6" keeps it nice and tight and clean.
Just curious what others use.
