1 - 7 of 7 Posts
2013 3lt 2.0T 18" wheels
1.) While going over bumps at low speed- Either this issue developed in my head and has always been there OR something what feels like the front-right is not quite right. Sometimes I hear a rattle/bump/thump but sounds like something is not being held in place. My last car had a control arm bushing fall apart it would flop when turning but that was obvious sound and feeling. With my malibu it's much more subtle like a loose or worn bolt? Nothing obviously wrong
2.) Are my shocks shot? How can I tell? Attaching pictures of my struts and a ball joint outer tie rods which do not appear to be serviceable
Automotive tire Motor vehicle Wood Wheel Tire
Bicycle part Bumper Gas Rim Auto part
Leg Sleeve Glove Automotive tire Font
Mileage ?
Sway bar links are a common wear item.
Pry bars and weight off/on suspension while checking looking for looseness is the usual method to diagnose.
Struts / shocks at 100k miles are worn out, weak and if not leaking oil usually will not make noise unless there mounting rubbers are shot.
I would guess swaybar links, but without looking at the vehicle it is strictly a guess
Unanimous 2 for 2. When it's not raining endlessly and I have some daylight I'll take a look at the swaybar links.
Stock replacement or are there better aftermarket non OE? They look... plastic?
I've used Moog greaseable ones when I did them on my old '09 'bu. OEM are not greaseable.
Reactions: DrivenDaily
2015 Malibu 1LT with the 2.5L engine!
Just so you know I replaced all 4 shocks at 67,000 miles and it fixed it... Now I have a different rattle noise probably something else like sway bar links
1 - 7 of 7 Posts
