Boy it is frustrating sometimes when I need to turn my car and not have the headlights turn on automaticly. So a while back I got the manufacture 3 book manual, for $14 off ebay: everyone else wanted $60 -70. But these books can be confusing so I am turning to you.
What fuse is the automatic headlight system (know it is the engine fuse box)?
And a side note the fuse or module for the door chime?
Thanks for any help.
On almost all cars with daytime running lights, and automatic night time headlights, if you depress the emergency brake to the first detent position, the lights do not come on. I am sure you have noticed that if you start your car with the emergency brake on they do not come on. The first detent position should serve the same function.
If you want a PERMANENT solution to disabling the ALC and DRL there are instructions for this on MP Racing's website, www.mpracing.org/forum . I've done both on mine as well as a little modification to the directions.
Just don't remove any fuse or relay, this will not work and will turn on the SES light, I tried it to see.
On my old '98 I had back in the day, all I did was pull the fuse. Worked fine and gave me no SES light. Honestly removing a fuse for the lamps should not give you a service ENGINE soon light. I pulled the fuse on my previous G6 GTP, and on this Malibu as well. No SES lights.
