Could be, get it load tested to be sure. AGM batteries are not cheap.I have a 2019 Malibu RS. Just started with the steering assist reduced warning and the little shake in the steering wheel at restart from start / stop. The car is at 50,000 miles right now. Battery time?
Thanks!I moved your previous posts into your new discussion.
You can change the battery yourself. I did mine, painless. It is more work that many older cars but typical for a modern car. Like Repairman said above, the AGM are a bit more pricey. The OE 48AGM runs about $160.
