My cruise control on my 2008 LT2 V6 sometimes doesn't work. The problem is quiet intermittent and I knew it would be hard to get it fixed if I couldn't reproduce it in front of a mechanic. Well today I finally figured out what the problem was!
It was humid on the way home, and it was at night, so today I could tell that the cruise control sometimes doesn't turn on because sometimes the brake light goes on when I am not applying the brakes! (I could see the reflection of the center light on the condensation in the rear window)
The malfunction was actually kind of strange. If I applied the brake the light turns on, and then when I release the brake the light would turn off. However 5-6 seconds after I released the brake the light would turn back on. I did it a couple of times and then counted the time between when I let my foot off the brake and the time the light came back on and it was always almost exactly 5-6 seconds -- after that time the light would go on and stay on forever. Of course I could apply the cruise control during the 5-6 seconds while the light was off but once the light turned back on the car refused to let me turn on the cruise control (although now I am more worried about the safety issue of having my brake lights act weird.)
Another strange thing with the light is that if I just applied a little pressure to the pedal, not enough to actually slow the car down, the brake light would actually turn off. The light seemed to turn off the entire time I applied that little bit of pressure, but once I totally let up it seemed to reset the 5-6 second "clock" and then the light would just go on after that.
Anyway I am thinking that there is something messed up with the brake light switch. I am guessing that it needs to be replaced or adjusted. Can anyone give more directions on how to adjust/replace it? I am guessing the brake light activates by a simple switch but if the mechanism is more complicated (like it is computer controlled for some unknown reason) then can anyone think of something else causing a weird brake light problem?
Thanks,
Matt.
Thanks,
Matt.
