I have a 2015 Malibu LTZ with the factory 19” performance wheels and I’m wanting to get 20” camaro ss wheels for it but not sure it they’ll fit... someone tried this?
'00 Malibu base, '01 Malibu base, '07 Uplander LS EWB, '17 Equinox Premier V6 AWD
Both cars use a 5x120 bolt circle and nave a similar offset. The fronts on the Camaro are narrower than the rears, so I would consider using two pairs of fronts (or rears). I read somewhere that a person swapped in front brakes from a Camaro also. I'm considering using the front wheels (and maybe brakes) from it on our Equinox. The 20 inch wheels from a Buick Regal GS will definitely bolt right up, but I'm not sure if you would like how they look on your car. You can check it out at wheel-size.com. Car-part.com is a great place to get used parts from salvage cars if you don't want to buy from a dealer.
