Yeah, the same goes for the factory fog lights. You can get the entire package (lights, relay, switch) and install it but it won't work until you go to a dealer and have them reflash the BCM to "see" the fog light switch.
That's why on my '09 2LT I wired in my own switch, etc.
Besides, I've discovered on my '11 that the fog lights don't come on the next time the lights do if you parked the car with them on. You have to turn them on each time! That's nuts! And the switch is hiding behind the steering wheel where you can't see if it's on or not. I took care of that as well in my '09 by putting a low-output LED right below the speedo to indicate when they were on, and the switch I installed was a simple rocker. It didn't reset to off every time the key was cycled! It was wired so that the fogs could come on only when the key was on, the high beams were off, and the parking lights were on.
