This morning, after dropping off my daughter at school, which is about 1 mile away from home, I decided to drive back home to change out the old power steering fluid for my chevy malibu 2003.
What I did was that I sucked as much old fluid as possible from the reservoir and then added new fluid to the correct level. I started the engine and make a few full left and right turns. I shut down the engine and went in to wash my hands before going to work.
Just a few minutes later, as I attempted to turn on the engine, it refused to start. The cranking seemed fine but the engine simply didn't want to start.
I thought it might be some PS fluid spills on the belt, so I loosened the belt and gave it a clean wipe. No luck. The engine still refused to start.
I also tried disconnecting and reconnecting the battery, hoping that would kinda reset the computer. But that didn't help, either.
I did more troubleshooting steps:
1. depressed the schrader valve on the fuel rail and no fuel came out although there was fuel smell;
2. checked the ignition module or an old spark plug and it sparked properly;
3. checked the relays by swapping good one with the one that controls fuel system and that didn't help;
4. turned the key to ON without starting it and heard NO sound from the fuel pump.
Maybe some sensors have gone wrong? Or, the fuel pump decided to retire after 75, 000 miles of service? Any advice will be highly appreciated. Thank!
