1 - 20 of 23 Posts
Well this weekend we finally changed the oil in the Malibu and let me tell you what a PITA. The drop in filter cover is about in the most retarded spot you can have it. I had to use a pair of channel locks to get to it because the DIY autoshop I was at didnt have a shallow enough socket.
Finally got it done but I wish it still had a regular oil filter.
Any advice for next time? What do all of you other DIY guys use to get the filter cover off?
Hmmm, the 2.2s have the same size filter?
Ill go to AZ and ask around. The one I go to has a pretty knowledgeable manager which is a huge plus.
Amazon has one for $7 Search for Lisle 14700 Oil Filter Wrench for GM 2.2L
I just bought a 32mm socket from Advanced Auto for my wifes old Alero. It had the 2.2, but I'm pretty sure it's going to be the same as on the 2.4. I believe the socket was between $7-13. No need to get a special one, any old 32mm will do.
Discussion Starter · #16 ·
No, they wont. The intake runners on the 2.4 get in the way of the regular socket. You need a very shallow socket to get it on the actual cover.
I would check yours as well.
Interesting, if you use an extension will it work? I know that I used a 12" extender rod in order to use the socket I bought. I know something got in the way on the Alero, but I can't remember what it was. I hope I don't have to buy another one since I've already got a socket. When I pick my car up tomorrow I'll have to check it out.
Discussion Starter · #18 ·
An extension will not work. At least on the 2.4 it wont.
Hopefully yours will work for you but dont be bummed if it doesnt. :D
Yeah I can't remember if it was a radiator hose or just some other wires that got in the way. What's the difference between the two engines? Is the 2.4 just a bored out 2.2 or are they two totally different engines? I have to say I do love the filter being on the top of the engine. It saves a huge mess.
Discussion Starter · #20 ·
I just poked a hole in my old filters. No need to try to keep them together as they will be crushed anyway. I cant say I like the higher prices on the filters either.
Displacement for the 2.2 L engine is 2196 cc (134 cu in) with an 86 mm (3.38 in) bore and 94.6 mm (3.72 in) stroke. Compression is 9.5:1 or 10:1, delivering 135 to 143 hp (101 to 107 kW) and 142 to 152 lb·ft (193 to 206 N·m) of torque.
The LE5 is a larger 2.4 L — 2376 cc (144.9 cu in) — version of the Ecotec. Both the 88 mm (3.5 in) bore and 98 mm (3.9 in) stroke are larger, and Variable Valve Timing on the intake and exhaust improve low-end torque. Compression is 10.4:1. Power is 164-177 hp (123-132 kW) and torque is 159-170 lb·ft (215-230 N·m).
Basically its bored out and has VVT.
1 - 20 of 23 Posts
