I tried to change the brake lights. I unscrewed the wingnuts and when I tried to pull the assembly out I noticed it was stuck. I'm not taking off the entire bumper to change 1 bulb, any work around? I also will have to buy 2 new bulbs, because I got so mad I stepped on them.
It is hard to tell from your description if you are trying to change out entire assembly or just a burnt-out bulb as you seem to say both in your question. If just a bulb, see . Looks pretty straight forward. Good luck.
Thank you. All of the videos I saw were either for 2017 or showed I would have to take the whole thing out. I only needed to change out the bulbs.
